Hope you check into this forum often...
I have some progress and yet some problems.
I can open a connection to the EST, initialize it, start & stop the target. 🐵
I can't read memory, write to the target register or program the FLASH, yet. Do you have any advice on how to get further with this?
I can convert to CVI if necessary. I am using the dll's from WindRiver.
My problem is that I am not sure if I am passing void pointers back & forth correctly. For instance, I need to call a function which returns a status, as follows:
status = EST_WriteTargetRegister (long handle, Unsign int register, void * value)
How do I pass the "void * value" to the input of a Call Library FUnction Node. I did try "Adapt to type" which does give a "void
* value", and I tried both "Handles by Value" & "Pointers to Handles".
- Thanks -
