LabWindows/CVI
Has anyone created a power point slide from a CVi application
I've been asked to create power point slide from a CVi application.  Has anyone done this.  There are word and excel examples.
(4,061 Views)
no ,as far as i know
(4,031 Views)
Depending on what you want to do, it should be possible to interface between CVI and PowerPoint using ActiveX.
Take a look at the built-in CVI example for PowerPoint.  Go to Help >> Find Examples.  Click the search tab and search for PowerPoint.  There is an example called simple2000.cws that may help you get started.
(4,010 Views)
