Thanks Bilal,
I tried it and it didn't work, atleast not when I tried
http://user:pwd@host/. For now I have the base64 encoded values of the
username/pwd (as these are not changing in my case), I just need to
figure out how to send this autorization header.
The article you referred mentions some RFCs along with some sample code,
I will go through them.
vishi
bilalD wrote:
> CVI does not have any functions for the base64 encoding, but
> href="http://www.pocketpcdn.com/articles/http.html">site talks
> about how you would do this. The actaul encoding class doesnt use MFC,
> so you should be able to get it to work.
> Once you get the base64 string, you should be able to add it on the
> basic connection url with the following format
> http://<
User>:
> If you do get this to work, let me know, I havnt really tried this
> myself.
> Hope this helps
> Bilal Durrani
> NI
