LabWindows/CVI
Graph 3D XYZ
Hi everybody,
I wonder if it's possible to plot a 3D graph if I have X Y and Z (for example X=(a,b,c,d), Y=(e,f,g,h), Z=(i,j,k,l)). I try to plot it with different fonction which could plot mesh or curve but i prefer to just have some point with xyz for coordinates.
So I think that a good function could be a function who wanted x,y and z vector like i said before. Moreover, the must could be a XY projection with a color point to determinate z value. So if you have some ideas, don't hesitate to answer Smiley Wink.
THANKS.
(4,791 Views)
Accepted by topic author Bouyakaz
Is the existing 3D graph control unsuitable for your needs?
the tool can be found in toolslib\custctrl\3DGraphCtrl.fp
there is an example in Samples\UI\3DGraph\Simple 3D Graph
(4,771 Views)
I will look at this example tomorrow to see if it could be interessant for what i needed. Thanks.
(4,763 Views)
Yes, i find how it works. Thanks.
(4,732 Views)
