I'm using the instrument "excelreport.fp" to generate excel files and then print these excels file with a pdf printer. This instrument uses "Microsoft Excel 9.0 Object Library" which doesn't offer possibility to directly save excel file under .pdf format.
This functionnality is available in newer Excel ActiveX controller like "Microsoft Excel 14.0 Object Library".
My question is: is there a new revision of "excelreport.fp" instrument which includes this functionnality?
Because, the high level of this instrument is very usefull for my application and I would like to avoid to completly develop the same kind of API using "Microsoft Excel 14.0 Object Library".
Thanks a lot for your help.
