Ian-Qld,
What happens if you specify channel 9? Agilent enumerates their oscilloscopes' channels beginning with 0 (zero). In this case, sending a command to read from "10" would correspond to the 11th channel (if you start counting at 0).
Otherwise, if you are successfully able to send commands and receive responses, your board is most likely working perfectly.
Alan
