LabWindows/CVI
Facing Problem in Deployment App with Database (Very Urgent)
I have an application which is using SQL toolkit 2.2 to access database in MS SQL Server through ODBC. When I deploy my application, it does not access database and gives error while reading/writing in database unless the SQL ToolKit is installed. When SQL Tool kit is installed on deployed system, it works fine then. Window Xp is running on deployment system. I want that it should work after deployment without SQL Toolkit installation. I have read the document "Distribution Instructions for LabWindows®/CVI Executables Using the DLLs of the SQL Toolkit Database Driver (Part Number 320981B-01)" and I am unable to find the DLLs list mentioned. Please guide me regarding the issue.
Thanks in advance.
Umer
(4,310 Views)
Thanks to reply
I am unable to find
CVISQLShared.msm
sqldistsupp.exe and sqldistsupp.dsn
Kindly help me
umer
(4,255 Views)
