LabWindows/CVI
Extracting numbers from a char array
I am using LabWindows/CVI to read data from a serial port.  I read the values with ComRdTerm, and they are stored in a char array, the
array looks like this "1024 576 123 756". I need to extract the numbers from this array.
(2,779 Views)
Accepted by topic author adrian_necula
ANSI C sscanf () and Formatting and I/O Library Scan () functions are the instrument you can use to extract your numbers. A good C manual will explain you the first command and its options, while for the second there exists a good descrption in the online help.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(2,771 Views)
Thank you, it worked
(2,756 Views)
