LabWindows/CVI
ExportAsFixedFormat PDF generation
I would like to be able to save an excel file to PDF in labviewdows cvi. In labview I have code that uses the exportasfixedformat method, however, I cannot see exportasfixedformat in any of the excel examples I have. I see a bunch of calls that use CA_MethodInvokeEx, however, not exist for the exportasfixedformat.
How can I create one for the excel2000.c file I found in my examples?
(4,471 Views)
Accepted by topic author Steve_Block
Turns out I was able to generate some current .c and .h files from the Tools-> Create Active X feature. It was a painful process, but I no longer need a solution.
(4,462 Views)
I think you used the feature Tools >> Create ActiveX Controller, but you didn't clarify which ActiveX you selected to create the .c and .h files.
Could you share this info, please?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,331 Views)
I used the Microsoft Excel 14.0 Object Library.
(4,321 Views)
