03-04-2016 10:16 AM
I would like to be able to save an excel file to PDF in labviewdows cvi. In labview I have code that uses the exportasfixedformat method, however, I cannot see exportasfixedformat in any of the excel examples I have. I see a bunch of calls that use CA_MethodInvokeEx, however, not exist for the exportasfixedformat.
How can I create one for the excel2000.c file I found in my examples?
03-04-2016 01:02 PM
Turns out I was able to generate some current .c and .h files from the Tools-> Create Active X feature. It was a painful process, but I no longer need a solution.
03-17-2016 02:39 AM
I think you used the feature Tools >> Create ActiveX Controller, but you didn't clarify which ActiveX you selected to create the .c and .h files.
Could you share this info, please?
03-17-2016 07:46 AM - edited 03-17-2016 07:47 AM
I used the Microsoft Excel 14.0 Object Library.
