LabWindows/CVI
Excel Report - Save to specified location?
I've been using the Excel Report library to generate an excel sheet for a CVI project (CVI 2015). The library is working fine when I load it as an instrument to create new sheets, rename worksheets and change the file name but I can't seem to find a way to tell the sheet where to save it. I'd like to be able to save it to a specified folder so I'm wondering if there a simple enough solution to this or do I need to change approach?
Thanks.
(2,337 Views)
How are you currently writing your files in CVI, and where it is saving to?
Thanks.
(2,259 Views)
Hi SasounT,
Thanks for the reply, I did actually manage to figure it out - I wasn't including a double backslash for the file path/name - but thanks for the reply.
(2,210 Views)
