LabWindows/CVI
Excel Library
Is there a tutorial for the Excel libraries used in CVI
(2,907 Views)
Hello
We have some examples that demonstate how to use Excel activex functionality from CVI, that would be a great place to start from. You can find them in your CVI folder under ..\samples\activex\excel
Just to point out though, CVI provides you access to already existing methods and properties of the Excel Activex server. This was created by Microsoft,and to find out more about each method and property, you would need to refer to the Microsoft Developer Network. Once you figure out how the Excel object model works, from there on, its just a matter of finding the correct function in the CVI wrapper.
Hope this helps
Bilal D
urrani
NI
Bilal Durrani
NI
(2,907 Views)
