02-06-2013 02:35 PM
I am a programmer on FRC robotics team 1257, and I need to write some custom image analyzation code. I want to loop through two slighlty different images and find the average x position of the change in green between the images. I also want the average color of the area that changed (that part works).
// info1 and info2 contain valid data rgb* pixelImage1 = (rgb*)info1.imageStart; rgb* pixelImage2 = (rgb*)info2.imageStart; for(int y = 0; y < info1.yRes; y++) { pixelImage1 += 5; pixelImage2 += 5; for(int x = 5; x < info1.xRes; x++) { // Do the processing if((int)pixelImage2->green - (int)pixelImage1->green > 150) { if(y < 120) { if(pixelImage2->green > 70 && pixelImage2->red < 150 && pixelImage2->blue < 150) { averagePosX += x; red += (int)pixelImage2->red; green += (int)pixelImage2->green; blue += (int)pixelImage2->blue; total++; } } } //////////// pixelImage1++; pixelImage2++; } pixelImage1 += info1.pixelsPerLine - info1.xRes + 5; pixelImage2 += info2.pixelsPerLine - info2.xRes + 5; }
rgb is a struct that looks like this:
struct rgb { unsigned char blue; unsigned char green; unsigned char red; unsigned char alpha; };
Any help you can offer would be appreciated. Again, we are finding the color correctly, but the x value (averagePos) is definitely wrong. The nested if statements are just restrict our search in the image.
02-07-2013 11:29 AM
Hi soystuff,
For all FRC related questions, you will want to use http://www.ni.com/frc
Click on the Discussions Tab to post questions relating to LabVIEW, FRC, and any of the utilities. If you are looking for help relating with C++ or Java, then you will want to use the corresponding forums for these languages. For example, http://www.chiefdelphi.com/forums/portal.php has a really good C++/Java community. In addition, US FIRST has a really good list of technical resources available for C++/Java programmers here: http://www.usfirst.org/roboticsprograms/frc/2013-Technical-Resources
Sincerely,
