LabWindows/CVI
Ethernet with e4438c %3F
Hello everybody,
I want to know iuf it's possible to command a Agilent e4438c ( Vector Signal Generator ) with labwindows through an Ethernet connection. I find drivers for GPIB connection on agilent website but it will be better with Ethernet.
So is it possible with Labwindows to pilot it in ethernet ?
THANKS.
(4,670 Views)
Look at the datasocket examples.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(4,638 Views)
If the Ethernet port can be used for programmatic control and the instrument is VXI-11/LXI compliant, you can just use the IVI driver as is. Have you tried or have you contacted Keysight?
(4,617 Views)
Yes, the ethernet port is VXI-11/LXI compliant, i will look at the IVI dirver with more precision. It's a little difficult for a beginner because there is not a lot of example on internet. I will contact Keysight to try to find the best way to connect the e4438c.
(4,597 Views)
I configured my system and it communicate well with other utilities like MAX.
But, when i try to run my labwindows program, with SICL language, it doesn't work, it seems to communicate but not to follow the other instruction.
Some command of my program :
char* instOpenString ="lan[20.250.11.3];
INST id=iopen(instOpenString);
if (!id)
fprintf(stderr, "iopen failed (%s)\n", instOpenString);
return -1;
 iwrite (id , "*IDN?\n" , 6 , NULL , NULL );
 itimeout(id, 2000);
 iread ( id , buf , 200 , NULL , &actual );
 iclose(id);
I have no return reponse so i think the connection works well, but buf and actual never change, it's like if it didn't read anything.
(4,519 Views)
SICL? Really? Why post on a CVI forum? Go to Keysight or use CVI with the IVI driver and follow the examples that come with CVI.
(4,513 Views)
