02-04-2013 03:53 AM
I am trying to make a distribuation disk for an old project with a CVI 2012 version but i can't get it to work.
I can run the application in debug mode and even make the distribution kit without errors but
when i try to install i get the error massage ".\distribution.cpp(5890):installer error 10011
Fatal error value out of range <no debug imformation>"
Where can i found the value that feil??.
Best regards
Eugen
02-04-2013 04:31 PM
This error has been reported a few times in the past and was solved by one of the following two solutions:
02-05-2013 01:32 AM
Thank you for four reply the problem seems to be solved by deleting the "cvibuild" catalog.
Eugen
