LabWindows/CVI
Error: This installer requires Windows 7 Service Pack 1 or later
I recently updated LabWindows/CVI.  I thought it was just the license manager, but .NET and Visual C++ 2015 runtime files were also modified.
I rebuilt one of my programs, creating a distribution kit.  Now when I try to run the installer on Windows XP I get the following error: "This installer requires Windows 7 Service Pack 1 or later".
My development computer is Win7 with LabWindows/CVI 2013 ver. 13.0.0 (647).  My target is a WinXP machine.
What is the fix or workaround for this problem?
TIA.
Message 1 of 12
(13,169 Views)
Just a guess (maybe better than nothing Smiley Wink): did you install the run-time of CVI2015? You can check the version of cvirte.dll to find out. This might explain your findings since CVI2015 does not support XP anymore
Message 2 of 12
(13,154 Views)
Your mentioning of .net and C++ runtimes makes me think: are you using them in your application? In this case, are you sure these releases can be installed on XP?
Message 3 of 12
(13,152 Views)
I'm using version 2013, SP1, which is "supposed" to be compatible with WinXP. To the best of my knowledge I'm not using .NET or Visual C++ 2015 runtime in my program. How can I tell? Is that something I have to do explicitly? I tried editing the distribution kit setting under Build->Distributions->Edit ...->Drivers & Components. I've always just used the NI LabWindows/CVI Shared Run-Time Engine. This time I expanded it and unchecked .NET Support and ActiveX Container Support. Everything else was checked. There is not a checkbox for Visual C++ 2015 Runtime or Redistributable, but there are checkboxes for Visual C++ 2008 Redistributable/Runtime and 2010 Redistributable. I left those checked since they've always been checked before. Made the distribution kit and tried to install on WinXP - same error. Tried again, this time unchecking the Visual C++ redistributales and runtime. Same error. Any more suggestions?
Message 4 of 12
(13,135 Views)
Wolfgang raised a good point in my opinion: some installation or update could have installed CVI2015 RTE: you can check which version is installed in Control Panel or in MAX or by issuing a GetCVIVersion () command within CVI.
In case a different runtime engine is installed that cannot be ported to XP, you should build your executable binding it to CVI2013 run-time and include it in the distribution: see this page for help
Message 5 of 12
(13,132 Views)
I went to Build->Target Settings and changed the Run-time engine binding to 2013 side-by-side for entire application. Next I went Build->Distributions->Edit...->Drivers & Components and checked NI LabWindows/CVI Side-By_Side Run-Time Engine 2013 Patch 1. That's the only thing checked. There is no 2015 RTE option. Same error again. I checked for installed items at Control Panel->Programs and Features->National Instruments Software. The latest RTE listed is 2013 Patch 1. Strangely enough, the Installed On date listed in the Programs and Features window shows 7/5/2016, which is the date I installed the critical updates. Unfortunately the National Instruments Software windows does not have dates associated with the components.
Message 6 of 12
(13,128 Views)
I am not sure this is a reliable way to search for the RTE version, in my opinion it is better to search for the file cvirte.dll, then select Properties / Details.
Alternatively, as Roberto suggested, use the GetCVIVersion () command within CVI.
Message 7 of 12
(13,124 Views)
The command GetCVIVersion returns 1300, and GetCVIVersionYear gives me 2013.  The version of cvirte.dll in C:\Windows\System32 shows LabWindows/CVI 2013 for Product Name and 13.0.0.647 for the Product Version.  The one under \Windows\SysWOW64 says the same thing.  I can't find anything related to CVI 2015.
I also tried creating a debug version, but had the same error message.
Either I wrote down the error message wrong, or it has changed.  Now it says "installation" rather than "installer".  Could be a goof on my part.
Message 8 of 12
(13,121 Views)
So it seems that my guess was wrong...Unfortunately I have no other idea...
Message 9 of 12
(13,106 Views)
Neither I have Smiley Sad
I wonder if it's just the WIndows Installer that is targeted to WIn7. Even if it were true, I wouldn't know what to suggest you to avoid this problem. Let's see if some NI folk has any idea...
Message 10 of 12
(13,098 Views)
