10-03-2013 09:57 PM
If I execute the function
DAQmxSetChanAttribute (countTask, "", DAQmx_CI_CountEdges_DirTerm, "Dev1/port0/line1");
Error 89120 appears when the task starts. Im pretty sure that that is a valid name for a USB-6215 terminal, so I'm confused. Should I configure a digital input (and therefore another task), before setting the value of the CI_CountEdges_DirTerm Atributte??
NON-FATAL RUN-TIME ERROR: ... Function DAQmxStartTask: (return value == -89120 [0xfffea3e0]). Source terminal to be routed could not be found on the device. Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names. Property: DAQmx_CI_CountEdges_DirTerm Source Device: Dev1 Source Terminal: Dev1/port0/line1 Task Name: DAQTaskInProject Status Code: -89120
10-04-2013 04:46 AM
Take a look at screenshot. In the help of "value" field you can read :
"Specifies the source terminal of the digital signal that controls the count direction if DAQmx_CI_CountEdges_Dir is DAQmx_Val_ExtControlled"...
Are you sure that you set the attribute which name is "DAQmx_CI_CountEdges_Dir" to that value ("DAQmx_Val_ExtControlled") ?
