01-31-2013 04:10 PM
Hi, I have started a new project that is currently using LabWindows/CVI, vxWorks 5.2 (Windows 2000 I believe). I will be interfacing with a (Cutronic - TM-9223F) motion control/rate table running vxWorks 5.2 and am looking for any assitance for upgrading this system. Any suggestions?
02-01-2013 03:39 PM
Hey Newton2This,
Which upgrades are you looking to make? Upgrades with the OS? How is your project being set up currently?
02-01-2013 03:48 PM
Thank you for the reply! The upgrade will most likely be to the UI. The current touch screen UI is still booted up with a 3.5 diskette running DOS. The requirements are still being determined so I am looking for the easiest or most practical way to create this interface. The OS most likely with NOT be changed. I am currently developing with LabVIEW 2011. John
02-01-2013 04:00 PM
...I do know the control panel itself has a RS-232 and modeled after IEEE 488 s/w protocol. The remote host that it is currently connected to has an emulator and handshaking. The panel itself has none and no flow control. The serial interface is set up for 8 bit data with 2 stop bits. Baud rate and parity are configurable.
02-04-2013 05:16 PM
Have you previously deployed from CVI to a vsWorks real time target? As it currently stands, CVI does not support vsWorks as a real time target. In fact, only PharLap is supported for RT by CVI.
02-04-2013 05:31 PM
hmmm... no, I have not previously 'personally' deployed CVI to a 'vxWorks' real-time target - however that is what is currently being used in our lab.... I will need to do some more checking on this... Thank you for bringing this to my attention....
02-06-2013 09:42 AM
After further study we believe patching into the panel via 50ohm BNC cables (+/- 10V, 350hz (input), 500hz (output), with 16 bit resolution) should do the trick. I believe there is a DDC 1553 Module for the Crio that should handle the A/D and D/A conversion. DOS version 6.22 is currently running on the panel. ouch! Have you ever heard of the 'Scramnet' protocol? The ACT 2000 (Actutronic) is currently using it.
