Hello
This is probably happening because CVI uses the default MSI ( Microsoft Installer) logic, which is to select the root drive as the drive with the most space. Im assuming in your case you have multiple drives and that E: probably has more space. You can work around this by forcing the install to the correct folder by using the msi command line parameters, as follows
setup.exe INSTALLDIR=C:\MyDir\foo
Let me know if I missed anything.
Bilal Durrani
NI
Bilal Durrani
NI
