02-13-2013 06:37 AM
Hi there,
I'm new to LabWindows and I'm working on a project that contains loads of files within a project.
I'd like to know if there's any tool available for generating a dependency diagram, something like Vi hierarchy in LabVIEW.
If not, is there any method for finding all function calls within a project (something similar to the 'find callers' method in LabVIEW) ?
I need to locate which .c files call my function...
I'm working on LabWindows 2012.
02-13-2013 06:48 AM
you can use the Source Code Browser (CTRL + F1) to list selected functions etc. You will need to compile the project first with the 'generate source code browse information' build option enabled.
