11-10-2014 10:56 AM
You can upload it on ftp://ftp.ni.com/incoming, like you did with the log.
11-10-2014 10:57 AM
But those files can be downloaded anonymously, correct? We have sensitive IP clauses here.
11-10-2014 11:03 AM - edited 11-10-2014 11:03 AM
Other users can't download the files from ftp://ftp.ni.com/incoming, only they can see the titles.
Only NI folks can download files.
11-11-2014 01:17 AM
Hello ElectroLund,
you are not alone with this problem.
I have a project with two DLLs from measurment device manufactures already included in the project.
If I include another DLL, written in LabView 2013 the programs hangs after reaching a breakpoint. I cannot continue. This happens all the time.
The position of the breakpoint in my code doesn't matter. I have tested this with several positions right at the start of the programm or in the middle of a routine.
Same project in CVI2012 has no problems.
I have already created a post with former problems of loading the LabView RunTime-Engine when using that DLL.
http://forums.ni.com/t5/LabWindows-CVI/CVI2013-unable-to-load-LabView-RunTime-Engine/td-p/2590579
Now with CVI2013 SP2 and that DLL, created now with LabView 2013, I am one step further but now having that debugging problem.
My project is really large and I cannot send it. If I can find some time I will try to reduce the project to the minimum and send it.
Gunther
11-11-2014 07:36 AM
gunthill, very interesting. I too had no issues debugging with this same project in CVI2012.
This project also has a several DLL files included for an FTDI RS232-USB bridge chip. I wonder if that's a common link.
12-19-2014 10:48 AM
Hello ElectroLund and Gunther,
When this hang happens, do you have any special windows in your program, like ActiveX controls or other windows then uirs?
Constantin
12-22-2014 12:06 AM
Hello Constantin,
I only use uir files in my project.
Best regards Gunther
01-05-2015 09:39 AM
Same here. Only UIR. Some of my projects have dlls, but never Active X.
01-07-2015 02:02 AM
Can you try samples\userint\activex\WebBrowser.csw example to see if the same hang happens.
You could put a breakpoint for example on Refresh() callback. Run the program and push the refresh button, the breakpoint should be hit. See if continuing execution the same hang happens.
Constantin
01-07-2015 02:49 AM
Hello Constantin,
I tried this example and set a breakpoint in the line void CVICALLBACK Refresh(...) as you suggested.
After stepping into the function
INET_IWebBrowser2Refresh (webHandle, NULL);
with F8, I went on a while stepping through with F10. No Problem. Then I tried to continue the program with F5 and then the program hangs.
I had to cancel the cvidebugger in the task manager and then the already known merror message pops up:
"LabWindows/CVI did not receive a reply to a debugging message"
So this might be a project/source with the reproducible error?!
Best regards and greetings for a happy new year.
Gunther
