08-20-2013 08:37 AM - edited 08-20-2013 08:39 AM
Hello NI,
the following scenario could be improved, I think
If I press the 'Debug Project' button (green triangle), compilation may start. Since this can take quite some time one may be tempted to press the 'Debug Project' button again. Interestingly, now the button gets dimmed, but also the build will fail.
This behavior could be repaired if the green button would be dimmed as long as clang is running ...
08-21-2013 12:00 PM - edited 08-21-2013 12:00 PM
Hi Wolfgang,
We are tracking your request in bug report #423029.
08-21-2013 12:30 PM
Thanks!
11-05-2015 09:11 AM
This bug is still alive (the button is dimmed only at the second click) but I can't find it listed in the list of known issues
11-12-2015 12:06 PM
This bug was unintentionally not marked as public. I changed it to be public and so it should start showing up in the list of known issues with the next update.
Luis
11-12-2015 04:37 PM
Thank you
