Hello ,
In my application , it uses TSQ to access data , and transmit it by TCP .Data acquired from a special RTU ,and written into TSQ , another thread read it from TSQ .The problem is that when running the application after around 1 hour , there will popup a windows system error prompt :"0x00000008 memory referenced by 0x68511e7b instruction ,the memory can not be written " ,once this error appeared, my application hanged immediately . Can trace it into my source code ? Your advise is highly appreciated . My OS is Windows 2000, and the programming tool is cvi 6.
David
