08-06-2015 12:45 PM
I am using the example Synch_AI-AO in the DAQmx folder and it works great for sine waves, pulses, triangle waves or anything periodic. However, I would like to output a noise array which is generated from the WhiteNoise function, which is continously updated every N seconds.
I have tried calling the StopCallback then the StartCallback after delaying for N seconds, but since I have to be in function when I call these callbacks I end up getting back to the place where I called them before exiting them (like recursion), which kills my program.
Is there a way to update output so that it doesn't cause the recursion issue that locks up my program?
Thanks.
Solved! Go to Solution.
08-07-2015 11:45 AM
Hi EricJR,
Rather than calling the StopCallback and StartCallback functions, have you tried calling the DAQmxWriteAnalogF64 function every time new samples are generated?
