01-18-2013 01:53 PM
I have a tab control as a major part of my program, and I've run into the issue that the first time I open the panel containing my tab control, many of the controls on the tab are not visible. They are not set to not-visible (code or UI control) I know this for certain. Sometimes the tab is empty, while other times it is a few of the controls which are missing. The items can be made visible by dragging the panel containing the tab control off of the display (like off the side of the computer monitor) and bringing it back, or switching to a different tab and back. Is there a known solution to this problem? It used to be fairly rare, but has begun occurring more regularly, which means it is a concern for me.
I'm using LabWindows/CVI 2010 on a Windows 7 computer.
Chris
01-21-2013 12:13 PM
Hello ckcook,
It would be helpful to know more about your program in order to determine the cause. Does this occur in multiple tabs in multiple program, or just a specific tab in a this program? Do all of the controls in the tab disappear, or just some of them? Does this occur under specific circumstances, or in a regular pattern? What type of controls are on the tab, and what ones are disappearing?
Jason D
01-21-2013 01:24 PM - edited 01-21-2013 01:30 PM
Hi Jason,
Sometimes the tab is completely empty, while other times it is a few of the controls which are missing. Most commonly it is either everything, or the LEDs that are missing. The LEDs are the most recent addition to the panel, if this provides any insight.
I've only used the tab control in 1 program. It is the tab which opens when I first open the panel containing the tab control. Once you switch tabs, the issue goes away, and thus I've only seen it on 1 tab. The occurance of this seems completely random, however it has increased in frequency recently, which the only reason I can think of is that I added more controls to the tab.
The tab mostly consists of Command buttons, text entries and check boxes. I've attached a screenshot of the panel to give you a better idea of what is present.
Chris
01-22-2013 02:45 PM
Hi Chris,
Are these controls visible on other tabs? It may be helpful to insert ProcessDrawEvents() or ProcessesSystemEvents() in order to force items to be processed. If this does not resolve the issue, it would be helpful if you could post a simplified version of your code that still reproduces the error.
Jason D
01-23-2013 11:17 AM
Hi Jason,
These controls are not visible on other tabs. Adding ProcessDrawEvents and ProcessSystemEvents both before and after the call to DisplayPanel did nothing.
I'll see what I can do about a hacked together version of my code that has the issue, but it may be a while before I can do it.
Chris
01-24-2013 09:19 AM
Hi Chris,
I was also wondering if you could let me know if you had any UI timers or asynchronous timers. Also, does this only occur on startup? Posting your code will still be very helpful, so I would still definitely recommend posting that when you have the time.
Jason D
01-24-2013 10:26 AM
Hi Jason,
I do have some UI timers, but they are not on the panel that has the issue. This issue has only been observed the first time the tab is displayed after program startup.
Is there an issue with the timer that could cause this problem?
Chris
01-25-2013 09:49 AM
Hi Chris,
The reason I asked about timers is because a colleague had seen one issue where the UI was being written to at two points at the same time due to timers and this caused some issues. Although this is still possible, it does not look to be the issue.
It sounds like the issue is occurring at some point in the startup portion of your code. This should narrow down the area of code needed to reproduce your issue, so that you can post it.
Jason D
02-01-2013 12:49 PM
Hi Jason,
The issue has started appearing on another tab. It is a new control I added that is having the issue. The control is a List Box.
I've attached 3 screenshots. The first has the list box missing its border and scroll bar. The second is after an entry is placed on the list. This one has the scroll bar back but the border is still missing. The 3rd and final is after I've dragged the panel off of the screen, which makes the border come back.
Let me know if this provides any more insight to the issue,
Chris
02-01-2013 01:02 PM
As an additional note, hiding the control and making it visible again in code makes it display properly when it comes back.
