01-14-2014 04:23 AM
I am configuring a NI6509 and not sure how to remove a latching problem on the input. Power up state is set to Tristate which I thougt was correct. However, in CVI when i monitor an input that is High I recieve a correct High response. When i make that input Low and monitor I recieve an incorrect High response. If I then reset the card in MAX and run the function I recieve the correct Low response.
Is there any way to stop this latching effect in MAX?
01-14-2014 04:51 AM
The test panel works in MAX, so it must be the CVI environment set up ..may be mx version..not sure
01-14-2014 06:22 AM
The driver that I was using worked within cvi 8 and cvi 2010.
Currently, In order to for the driver to work under CVI2012 I have had to include DAQmxResetDevice ("Dev"); to reset the NI6509 before an input change can be read. Is there a change in CVI2012 that requires this?
01-17-2014 04:25 AM - last edited on 04-17-2024 02:23 PM by Content Cleaner
Hi there,
Are you still experiencing the problem?
Are you using a PCI or PXI NI 6509?
What version are your drivers?
The latest I can find are:
https://www.ni.com/en-us/support/model.pci-6509.html
https://www.ni.com/en-us/support/model.pxi-6509.html
Is tristate what you want? This means the output will have High, Low and Float states.
I hope this helps.
