Hello
You might want to make sure that all the UIR files being used are in the same folder as the executable. That is one of the requirements of the UIR. Unless ofcourse you use the UI to code converter to embed the UIR into the executable. That way, you wont need to worry about distributing the UIR and the executable. You can just provdide the exe.
Bilal Durrani
NI
Bilal Durrani
NI
