Hi -
As mentioned in other posts, I'm writing a small app using TCP. The twist is that the program has little knowledge about the incoming TCP messages -- it doesn't know how many it will get, or how long they will be, or when the server has stopped sending them.
My idea is to put the read into a loop (inside the TCP callback routine), and continue as long as the reads are successful. When the read finally times out, I'll interpret that as the end of incoming data and begin processing it. Not the cleanest solution, but all I can think of right now.
Issue: while I'm debugging, when the timeout occurs, I get a pop-up error informing me of the error. This is OK (though not particularly desirable) while I'm debugging, but it would be unacceptable if this happened in the production version of the code. So:
1. will this happen when the program is distributed, or is this just a feature of the debugger?
2. can I suppress it in the debugger? I don't really need this pop-up.
Thanks.
