11-23-2013 10:59 AM
I am using the example of getting data from rs 232 in lab windows. I want to use this in my final year project that's why I want to change its name that appears as "serial communication example" how can I change its name and how can I make its exe file that will run on any system even without lab windows.
How can I modify this example to save the data. I am very new to lab windows, I was using hyper terminal previously.
11-23-2013 11:07 AM
(1) Change the panel title of the serial.uir to something else.
(2) Running an EXE built with CVI requires that at least the CVI Run-Time Engine is installed on that PC.
(3) CVI comes with a File I/O that contains all you need.
11-23-2013 11:12 AM
the title is not getting changed. i have tried to click at tiltle but it is not having any text format in it.
11-23-2013 11:12 AM
If you haven't worked with CVI right now: Have a look at the "Getting Started with LabWindows/CVI" manual that comes with CVI. This thoroughly answers all basic questions.
11-23-2013 11:15 AM
(1) Open the *.uir.
(2) Select Edit >> Panel.
(3) Specify the Panel Title.
11-23-2013 11:20 AM
yes i got 🙂 thank you
can i save the data that i receive from my com port,as i was able to save the data in hyperterminal. can i also save in it.
11-23-2013 11:31 AM
I am not informed about the file format that hyperterminal uses. However, CVI allows wiring to files. To get a list of functions that deal with file handling, press <Ctrl-Shift-p> to get the "Find Function Panel" dialog. Type in "file" and press the "Find" button. This will open a list of funtions that contain "file" in their name.
