LabWindows/CVI
Changing Control Styles
Is there a simple way to convert 5.0 control styles in a UIR to new CVI 6
controls with all the characateristics of the original control, that is
wihtout havinf to retype them (Min, max, value pairs, colors etc?)
LVilla
(2,559 Views)
When i ran my CVI application under MS XP the first time, i decided i want to replace all buttons by 3D buttons, but only when the application runs under XP. My application has about 80 panels. So i wrote a function XP_PanelConform() to be called after loading a panel. It puts a 3D button on top of each button in a panel, depending on a flag in the ini file and on the MS system running. This function loads a background image for the panel as well.. Then there is another function XP_CtrlIdMap() called from the control callback common to all controls of a panel. This function maps the 3D button id (basically unknown to the existing software) into the original buttons control id, so callback functions basically need not be changed. Later i got two more functions XP_GetCt
rlAttribute() and XP_SetCtrlAttribute() to handle attributes of button controls.
This approach to get everything more XP-like took about one day and i am still with one UIR file.
(2,559 Views)
In the Tools menu, there is an item called "Convert UI to Lab Style". Is this what you're looking for?
Luis Gomes
NI
(2,559 Views)
