I am trying to develop an IVI driver for a switch we have that has multiple internal busses to route the signals to the external connections. I cannot connect two of the externals togeter using the NI-Switch Executive in MAX. It shows me the correct route, but then it gives me an error that the configuration channel required is already in use when I add the Route. i.e. To connect C01 to C03 the connections would connect C01 to Internal W01 then connect W01 to C03. In the Switch Executive it shows C01->W01->C03, then after selecting Add, I get the error.
