NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
David_Lee
Can use the same thread safe variable in the different processes?
Can  use the same thread safe variable in the different processes?  my application has a log file used to record some event, the log file will be accessed by the different process, is there any synchronous method to access the log file with CVI ?
David
Trusted Enthusiast
RobertoBozzolo
Rif.: Can use the same thread safe variable in the different processes?
Limiting concurrent access to shared resources can be better obtained by using locks: once created, the lock can be get by one requester at a time by calling CmtGetLock, the other being blocked in the same call until the lock is free. If you do not want to lock a process you can use CmtTryToGtLock instead.
Don't forget to discard locks when you have finished using them or at program end.
Alternatively you can PostDeferredCall a unique function (executed in the main thread) to write the log passing the apprpriate data to it.
Using LW/CVI from 3.1 on.
My contributions to the Developer Zone Community
If I have helped you, why not giving a kudos?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
