Hello
I guess I got a little thrown off by the title "panel loaded by another project". Are you trying to control one exe from another (inter - process control) ? Unless you have changed the project settings to generate a dll, Im going to assume that these panels are being loaded in some executable that you have created. And that, you want to be able to control those panels from another executable generated in another project.
One way you could have done this is if you made an activex server out of the controllee application, and the controller could be the activex client. But for that you would need CVI 6.0.
Another way for cross process communication ( in CVI 5.0) would be to use tcp.
If you just want to make sure that all your panels get updated corr
ectly (in the same process ), ProcessSystemEvents() and ProcessDrawEvents() should do the trick
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
