I would like to get a handle to an old ISA bus card with only the base address, select code and IRQ info available. It shows up in Devfice Manager as a non-Plug and Play Device (hidden). The option to add it in MAX does not have a category for it as best as I can see. Can I talk to this card in CVI?
Generally, the two things to look for when interfacing with CVI are whether the card has a driver and whether the API is compliant with ANSI C. Which ISA card is it that you are using?
