LabWindows/CVI
CWGraph
I am using the CWGraph component under MS VC++ 6.0. I have a strange
behaviour with the memory usage. I chart 6 plots with 4 Hz using the
ChartY-function. The graph increases the memory usage continously (in
intervals) so that when I run the measurement a few hours, the system
hangs because of lack of memory. I tried to cut the memory usage by
setting the chartlength to a given value of 140000 - no difference.
Does anybody had a similar problem and could give me a tip?
Thanks in advance!
(2,470 Views)
since this problem is unknown till now, please send me your sourcecode of this project. perharps you could reduce it to a simple example if your project is quite big or contains confidental information.
my email-address:
norbert.brand@ni.com
- Norbert
NI Germany
Norbert
Expert: Geometry
(2,470 Views)
