I tried the same thing using CVI 6.0, and setting DCWGraph3DSetEnabled() to VFALSE does seem to work. Did you register the callbacks correctly? I attached the project I tried. When the program loads up, click the OK button to register the click event. When you click on the control, you should see a message box pop up. Then Click the disable button on the UI, and now, if you click on the graph control, there should be no messgae box
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
