Hello Davidx,
i am not sure if something like this is possible. There is a good reason why NI uses installer: there are quite a few registry-entries and different folders to be created/copied.
The installer does this work for you, so why should we leave this service behind?
Because you have to change some entries in the registry, you must have admin-rights for you manual installation as well, so you cannot get around this point.
I would advise you to use the silent installation of CVI RTE. NI uses the Microsoft Installer (msi) so if you are missing parameters in the docu, feel free to take a look at http://msdn.microsoft.com/library/default.asp?url=/library/en-us/msi/setup/about_windows_installer.asp .
You can suppress an automatic reboot after installation wi
th the parameter "/r:n". But i do not know if the RTE works fine after the installation then.
Link for Knowledgebase entry refering silent installation of CVI:
http://digital.ni.com/public.nsf/websearch/3E617E265623F20F86256B53007DB77B?OpenDocument
Link to LabWindows/CVI RTE:
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/c5aceb508c6c143c86256da30056de80?OpenDocument
Link for example which registry entries are changed (old version of RTE!):
http://digital.ni.com/public.nsf/websearch/1B9DD6B42EEEF282852563850069E46B?OpenDocument
- Norbert B.
NI Germany
Norbert
Expert: Geometry
