10-28-2013 09:52 AM
Now I have tested your code again. I changed the structure of the code a little bit.
I can run the new code with no error.
Please see the attachment. My Code and Exe is called "myNI_test.exe" and "myNI_test.c"
Best Regards
Bernhard
10-28-2013 10:31 AM
I cannot run the exe-file neither your project from CVI. Always the same system error 998.
I do not understand why the your changes in the code should make any difference.
Gunther
10-28-2013 11:16 AM
ok.... mpf
I can also run your application if I change your code and structure of the worksheet like in the
following picture.
Perhaps this helps
10-28-2013 11:22 AM
Ok.....
one what you can try is:
->don't load an external modul in the Build>>Target Settings.
if you have checkmark there the external modul, please try to uncheck this.
10-31-2013 02:15 AM
I have reinstalled the complete CVI2013 FDS hoping that solves the problem, but still the same.
The option "Enable LoadExternalModule" is always disabled.
Gunther
10-31-2013 04:57 AM
Ok, this sounds not good.
Could you send me your current C Project and Workspace again, please. And screen copies
from all of your CVI environment settings.
I will try to reconstruct your settings and project. Maybe I find the issue.
Best regards
10-31-2013 04:59 AM
When you click on my Profile, you will find my eMail. In the case that the DLL and other things are confidential.
10-31-2013 06:16 AM
I cannot find your email address in your profile.
Gunther
11-04-2013 02:12 AM
Hi Gunther.
I write you back in the forum because it is maybe interesting for other CVI users.
I tried your settings and example. But I didn't obtained the error. I see in your source file
you have your project on an other drive than c: . Is 😧 your root drive? If not,
can you copy your CR project folder to your root drive( c:\) and try it again, please.
best regards
Bernhard
11-04-2013 03:39 AM
I tried it out, but this doesn't change anything (of course).
My original project is on c:\ (root drive). Only for separating I have made this test project on drive d:\.
I cannot see why it shouldn't work on another drive than the root drive.
Best regards
Gunther
