11-04-2013 04:16 AM
I've already reported a bug using excluded lines with CVI2013 (see here)
Now with f1 patch the bug has been partially fixed, but the problem is still there if you exclude lines (CTRL+E) in a heare file included from another header file (and not directly from a source file).
See attached example and exclude (CTRL+E) line 4 in dummy.h to see the problem.
Solved! Go to Solution.
11-22-2013 01:14 AM
Is there a bug ID and/or a CAR for this issue?
Even with f1 patch, I can't really use CVI 2013 for project development, since I has some important regressions compared to CVI 2012 SP1.
11-27-2013 03:26 PM
Hi Vix,
I have downloaded userint.zip
, and I have excluded line 4 from dummy.h
: #define _FORTEST //uncomment this line to view a control
. I am not seeing the behavior you previously reported.
Is there a specific preparation task you have to take before loading the file in order to see this behavior?
Daniel
11-28-2013 01:30 AM
Hi Daniel,
let me explain what you should do (and should see, I hope).
So, the problem is: CTRL+E in a header file included from another header file has no effect (the line is not excluded).
Could you confirm this, please?
12-02-2013 06:33 PM
Hi Vix,
Thanks for explaining further. I was able to reproduce the behavior, and I filed a Bug report (ID 439152) to track this. We appreciate your feedback!
Warm Regards,
09-26-2017 06:30 AM
Hi Daniel,
could you provide the CAr for this bug?
Has it been already fixed either in CVI 2015 or in CVI 2017?
09-26-2017 12:27 PM
Hi, Vix.
The CAR I filed was closed as a duplicate of CAR 431260, documented as a bug fix here: http://www.ni.com/product-documentation/52401/en/ .
I hope that helps,
- Daniel
