04-01-2015 09:51 AM
If I attempt to anything that requires a browse/file select LabWindows crashes with the following report:
Problem signature:
Problem Event Name: BEX
Application Name: cvi.exe
Application Version: 13.0.0.632
Application Timestamp: 51cb679b
Fault Module Name: CVI.dll
Fault Module Version: 13.0.0.632
Fault Module Timestamp: 51cb6792
Exception Offset: 00a4bb50
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1: 7d8b
Additional Information 2: 7d8b59960e847456f719cf8b76eb40a7
Additional Information 3: 1aa0
Additional Information 4: 1aa00fb74513a107a85e25616fae3f2c
Cannot add existing files to project, open new project or open workspace.
Started after loading NI-VISA.
04-02-2015 02:38 PM
I'm not sure why that error is occuring. That information alone probably won't be enought to figure out why this is happening. I would recommend contacting NI support to try and resolve this issue.
Kevin
04-02-2015 03:02 PM
Hi jimbrown60,
Do you see this problem after upgrading to LabWindows/CVI 2013 SP2?
Can you provide system information such as OS, OS-bitness, other software currently installed?
Have you tried running LabWindows/CVI as an Administrator (i.e., right-clicking LabWindows/CVI and selecting Run as administrator)? Does this cause a change in behavior?
Are there any errors logged in Windows Event Viewer? If so, could you clear the event log, reproduce the issue, and send the list of events logged?
04-03-2015 12:32 PM
A trouble ticket has been created and is being pursued. I have recorded the crash data via the ConfigCVILogging.exe tool.
Uninstalled and reinstalled the software and associated applications twice now. Something is being left behind or is scrambled in the registry. Unfortunatly I do not have administration right over my machine, so the process is slow.
I will report the final outcome, but at the moment I am looking at reimaging my machine to start a fresh install without any leftovers.
07-26-2015 05:11 PM
I have an exactly the same issue.
Is there any solution for this issue?
Ben
07-27-2015 05:25 AM
No I did not get a resolution. I ended up having IT flatline my machine and had to rebuild it. Good Luck.
I believe it all started when I downloaded an IVI library different from the NI library.
