01-16-2013 04:02 AM
Hi,I am new to CVI and I am working in a project using CVI8.5 to connect database using SQL toolkit. I connected it successfully. Now i need to retrieve it using a table in CVI. Which commands should I user egarding this function? Any help regarding this is very much appreciated
01-18-2013 03:37 PM
01-21-2013 10:24 PM
Thanks Steve I saved the required data in mdb format using CVI toolkit and retrieved it using CVI Table...also is it possible to do reporting in CVI?
01-27-2013 03:12 PM
If you want to develop a local database, it is easy to use SQLite. Embedd your database, has beutiful programming interface, and you can generate even function panlels and your own library.
download for free: sqlite.com
06-04-2013 03:53 AM
hi
i m new in cvi and i need your help
please contact me on my email addresss : houssnotes at gmail.com
06-04-2013 04:04 AM
HoussamCVI
I suggest you read this: http://www.catb.org/esr/faqs/smart-questions.html then come back when you have a precisely formulated question that follows the guidelines there.
06-04-2013 06:42 AM
SteveD123
I have to create a cvi application that use Database
and i don't know how to make connection between my application and the database
06-04-2013 06:47 AM
1. Create a connection between your PC and the remote server using Microsoft's ODBC.
2. Look at the examples that come with the NI SQL toolkit for CVI.
3. Read the help documentation.
03-07-2016 03:24 AM
lorsque j'ouvre CVI help ->library references ->je trouve pas Toolkits qu'est ce que je peut faire ????
merci
03-07-2016 05:07 AM - edited 03-07-2016 05:08 AM
Hello, depending on the product you have purchased you may not have the SQL toolkit included: see the comparison table for CVI-only purchase, which is valid unless you have purchased a Developer Suite, in which case the toolkit should be available on distribution disks and you may need to tinstall it separately (depending on the release of the base package included in the suite).
