03-07-2016 05:21 AM
If I may add: The LabWindows/CVI SQL Toolkit is included with LabWindows/CVI Full in version 2013 SP2 or later. So the Full Development System is sufficient, but of course the Automated Test Suite also works
You can verify this here
03-07-2016 05:32 AM - edited 03-07-2016 05:33 AM
Yes, this compares features of packages in within the same version.
I wanted to link a multi-version comparison table but I see now that is not automatically shown: you must select Features Since Version 9.0 tab to show the table
03-07-2016 07:14 AM
how to install SQL toolkit for CVI 8.5
03-07-2016 08:52 AM
Cvi 8.5 did not include the SQL toolkit which was to be sold separately at the time. I don't remember which was the exact release in use at that time, but I suppose every version from 2.0 on will install on CVI 8.5. The problem is whether you have it on your disks or not: if not you should contact your NI representative to see if it is possible to buy it now.
The toolkit came with its proper installer which that integrate the product into CVI.
