11-22-2013 01:45 AM
Hi guys. My problem is to see the Rigol DSA1030A as instrument in CVI. I have connected it via USB and following the guide I have downloaded the IVI driver where I haven't found any *.fp file.
Yestarday talking with a NI engineer he suggest me to use the VISA...but I have no idea. Is there any guide where I can read something? or by the way can you help me with this problem?
Thank you
11-22-2013 02:56 AM
I've never used any Rigol instrument, but you may possibly find some informations and link in this document from Rigol website.
11-22-2013 02:58 AM
To be honest I have already used this instrument with labview without problems.
Is it possible that they haven't rereleased any driver for CVI?
11-22-2013 03:39 AM
As I said, I never used Rigol instruments so I don't know the answer to this question.
In the document linked by Wolfgang in your other thread there indeed is a log (report.html) that refers to LabVIEW VIs being generated out of the CVI driver, so it should be available somewhere... There is also a .msi installer: did you tried running it? Has it installed some particular software or document?
11-22-2013 03:42 AM
unfortunatelly seems not. I tried to write directly to rigol to see if they can help me. I hope they'll reply soon.
thank you by the way for your interest and help.
If i reach a solution I'll write it here.
