05-10-2015 04:47 AM
Hi
I am currently working for a project which will run on a Raspberry PI with an arm processor. It is under Linux and I shall create the code with the CodeBlocks IDE.
I am now wondering if it is possible to create the software under CVI and run it under Debian Linux? If yes, is it possible to run it on a Raspberry that I can use CVI for this project? Raspberry PI runs under Raspbian which is a Debian Distribution of Linux.
So the question is, does CVI run under Debian Linux?
thx
Oliver
05-10-2015 11:30 PM
No, because the RPI is based on an ARM CPU, but CVI runs on and creates code only for Intel/AMD compatible CPUs.
05-12-2015 04:04 PM
Yes, but since CVI was moved to the CLANG compiler, there is no reason that it could not cross-compile to ARM. See http://clang.llvm.org/docs/CrossCompilation.html for example. Similarly, CLANG is a C++ compiler.
All features that NI choose not to enable in LabWindows, probably simply because of support cost considerations.
05-18-2015 04:05 AM
Sure, your prog will probably compile fine, but linking with CVI libraries won't work since you only have the binaries from the installer (no source), and those won't work on ARM.
05-18-2015 08:49 AM
thanks a lot for these informations
OK, then I have, unfortunately, to find an other solution.
thx
Oliver
05-18-2015 09:36 AM
I do a lot of ARM programming as well as CVI programming. My solution is to run the CVI code on an RPM-based linux system (I use Scientific Linux) with a user interface that is used to control low-level C programs running on the ARM-based systems. I've never used the Pi, but several Xilinx systems as well as Beagle board and others. They communicate via TCP. A bunch of script allows for compiling, cross-compiling, updating the whole thing. So it goes like:
(*) You can also compile and run the ARM part locally on the Linux PC, generating random data, allowing for easier testing/debugging
