12-12-2013 01:46 AM
12-12-2013 06:21 AM
12-12-2013 06:26 AM
Hello razvan.ioachim,
Did you try the Import/Export registry tool that comes with LabWindows/CVI?
=Nelu F. || National Instruments.
12-12-2013 06:29 AM
The application can be found under "Tools", in the LabWindows [version] start menu item.
12-12-2013 07:12 AM
12-12-2013 09:01 AM
I think I might have more suggestions for you. Did you try to open the profiler from Start > Programs > ... etc? Did you try to redirect the profiler output to a file?
If none of these suggestions work, your machine may be corrupted. The issue might not lie in the registry, but in a system dll or other component. We might be able to suggest a few registry keys that might hold invalid data, but that is going to take some investigation and might not yield the expected results.
In the end, you might have to format your drive and reinstall Windows...
12-12-2013 09:07 AM
08-27-2014 12:46 PM
Profiler wasn't loading for me either, and I got it solved via a support ticket. What I was doing wrong was that I had a call to
exit(0)
...at the end of my main(). This apparently was killing the Profiler toolkit before it had a chance to run. Solution was simply to remove it completely. It's not strictly necessary, as long as you have a call to
QuitUserInterface(0)
