Rafi,
This information is found in the TestStand release notes, which I have pasted below:
To run TestStand 3.0, National Instruments recommends that your system meet the following requirements:
� Windows 2000/XP/98 or Windows NT 4.0 Service Pack 6a or later (the TestStand User Interface Controls are not supported in Windows 98)
� 400 MHz Pentium class microprocessor (266 MHz minimum)
� 128 MB of memory (64 MB minimum)
� 500 MB of free hard disk space (100 MB minimum)
� SVGA resolution or higher video adapter, with a minimum 800 × 600 video resolution for small fonts or a minimum 1024 × 768 for large fonts
� Microsoft Internet Explorer version 6.0 or later (5.5 or later required)
TestStand 3.0 is compatible with the following National Instruments applica
tion development environments (ADEs):
� LabVIEW 6.1 or later (LabVIEW 7.0 or later is required to use the TestStand User Interface Controls)
� LabWindows�/CVI� 6.0 or later (LabWindows/CVI 7.0 or later is recommended for use with the TestStand User Interface Controls)
� Measurement Studio 7.0 (or later) Enterprise Edition is required for integration with Microsoft Visual Studio .NET 2003 or later
TestStand has more requirements that LabVIEW or LabWindows/CVI. These are the minimum requirements to run TestStand, and as with any software product, the better the PC, the better your application software will run.
The Run-time versions of the products do not change the minimum system requirements. This is because the components of the software which have these set minimums are still necessary for run-time execution.
If you have any other questions, please let us know.
Shannon R.
Applications Engineer
