09-30-2015 07:52 AM
Hi
I got a few Labwindows CVI 2013 projects that i would like to move back to 2009. How can i do this?
Labwindows 2013 and 2015 has to many bugs and is unreliable for me currently. I am also unable to debug my program due to one of the bug with 2013 and 2015.
09-30-2015 08:11 AM
09-30-2015 09:09 AM
Hi D-Cubed
Thanks for the reply.
I have put for a formal bug fix request. Its related to nested structure and the degugger returning a reference to a variable a deferenced null.
The other was with regards to running multiple threads and the only solution i found was to turn optimisation off.
I dont have back ups of the 2009 UIR, so that means i will have to do the UIR from scratch?
09-30-2015 09:13 AM
What Daniel was referring to is that you could try downgrading the UIR within CVI2013: open the UIR file and choose Save As, next specify as file type the release you want to downgrade to and a new filename to preserve original file.
10-01-2015 01:28 AM
Thanks Roberto for clearing that for me, i will definately try that out. Might have a problem because of the Tab control though.
10-01-2015 01:55 AM
I don't think so: tab control was introduced in CVI8 and 2009 release handles it in the same way as 2013, you should have no problems with it.
10-02-2015 02:03 AM
Thanks the save UIR as works.
Now i just got a windows SDK problem where CVI is complaining of some stuff in sal.h been redefined
10-02-2015 03:36 AM
sal.h is not present neither in my CVI2009 nor CVI2012 installs: have you installed also some Visual Studio version in your PC?
You could check Environment Options and see if some include file folder has been set there that you may replicate in previous release options.
10-05-2015 02:07 AM
Hi Roberto
I have added sal.h from the windows SDK but i am getting the following error :
It seems to beconflicting with the CVI 2009 SDK. I have not added the CVI 2009 SDK to my include paths.
Is there a way i cant fix this?
10-05-2015 02:22 AM
I cannot say for sure: apparently some macros are defined both in the new sal.h you just added and elsewhere in the source file listed, possibly in some other include file.
You should check whether you have only one sal.h in your system or whether those macros are defined in some other file.
The IDE normally identificates SDK folders without need to explicitly adding them to environment options.
