LabWindows/CVI
CVI 2013 "FATAL RUN-TIME ERROR: Pointer to free memory passed to library function" when accessing a struct from a struct
#include <utility.h>
#include <ansi_c.h>
#include <cvirte.h>
typedef struct StringsStruct
  char A[10];
  char AA[10];
  char B[10];
  char BB[10];
  char C[10];
  char CC[10];
} StringsStructType;
StringsStructType Strings = {0};
char *const SelectedStrings[3] =
  Strings.A,
  Strings.B,
  Strings.C
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                       LPSTR lpszCmdLine, int nCmdShow)
  if (InitCVIRTE (hInstance, 0, 0) == 0)
    return -1;    /* out of memory */
  strcpy( SelectedStrings[1], "TEXT" );
  /*** FATAL RUN-TIME ERROR:   "main.c", line 32, col 11, thread id 0xXXXXXXXX:   Pointer to free memory passed to library function. ***/
  Breakpoint();
  return 0;
Any chance to get this working in CVI 2013?
"&Strings.A[0]" doesn't work either.
/* Nothing past this point should fail if the code is working as intended */
(4,981 Views)
Accepted by topic author CVI-User
Hello CVI-User!
Thanks for reporting the issue. I have filed bug report # 423491.
I haven't had any luck getting rid of the error by changing the definition of the structure, but I was able to get the program running by disabling run-time checking when the structure fields are initialized:
strcpy( (char*)(uintptr_t)SelectedStrings[1], "TEXT" );
 Or maybe a more descriptive workaround:
#define UNCHECKED(x) ((void*)(uintptr_t)(x))
strcpy( UNCHECKED(SelectedStrings[1]), "TEXT" );
Peter
(4,948 Views)
Hi CVI-User,
Were you able to use the workaround provided to you by Peter? Is that acceptable to you for now?
Jonathan N.
(4,873 Views)
Yes, thank you.
This works for me.
(4,861 Views)
