08-20-2013 04:33 AM
#include <utility.h> #include <ansi_c.h> #include <cvirte.h> typedef struct StringsStruct { char A[10]; char AA[10]; char B[10]; char BB[10]; char C[10]; char CC[10]; } StringsStructType; StringsStructType Strings = {0}; char *const SelectedStrings[3] = { Strings.A, Strings.B, Strings.C }; int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpszCmdLine, int nCmdShow) { if (InitCVIRTE (hInstance, 0, 0) == 0) return -1; /* out of memory */ strcpy( SelectedStrings[1], "TEXT" ); /*** FATAL RUN-TIME ERROR: "main.c", line 32, col 11, thread id 0xXXXXXXXX: Pointer to free memory passed to library function. ***/ Breakpoint(); return 0; }
Any chance to get this working in CVI 2013?
"&Strings.A[0]" doesn't work either.
08-22-2013 05:47 AM
Hello CVI-User!
Thanks for reporting the issue. I have filed bug report # 423491.
I haven't had any luck getting rid of the error by changing the definition of the structure, but I was able to get the program running by disabling run-time checking when the structure fields are initialized:
strcpy( (char*)(uintptr_t)SelectedStrings[1], "TEXT" );
Or maybe a more descriptive workaround:
#define UNCHECKED(x) ((void*)(uintptr_t)(x)) strcpy( UNCHECKED(SelectedStrings[1]), "TEXT" );
Peter
09-05-2013 09:51 AM
Hi CVI-User,
Were you able to use the workaround provided to you by Peter? Is that acceptable to you for now?
09-06-2013 02:43 AM
Yes, thank you.
This works for me.
