05-21-2014 03:37 PM - edited 05-21-2014 03:38 PM
As the title suggests, I'm seeing very annoying behavior from my Variables and Call Stack window. I started scrolling quickly in the Globals list and the columns got all wonky. See screenshot.
It's as if the Globals section (column 1 only) got "thrown" down below into the Locals section.
The only known fix is to shut down CVI and restart the app.
05-22-2014 02:10 AM
Hello ElectroLund!
Thank you for reporting this erroneous behaviour you are seing in CVI with us!
Thank you!
- Johannes
05-22-2014 07:41 AM
Some answers:
06-02-2014 12:32 PM
Hello, ElectroLund!
We managed to reproduce the bug eventually. It seems that a mouse with free-wheeling isn't required for this, as it was possible for me to reproduce the incorrect behavior when dragging a column divider of the Globals tree of the Variables and Call Stack window, while at the same time performing scrolling with my regular mouse.
We have filed the issue under the following ID: #475321.
I don't have a better workaround for this, at the moment, than to prevent these 2 mouse operations from happening simultaneously (dragging a column divider while scrolling). However, if the incorrect behaviour does occur, the best way to restore the Variables and Call Stack window is to restart CVI.
Best regards and thank you for your valuable feedback!
- Johannes
